King-Marqy
Apr 02, 2019Aspirant
Lan 2 Lan connection setup
Can anybody advise me? We've got two SRX5308 on different sites (A+B). The sites are currently connected using VPN but this is unstable. The provider of the fibre connection has made a direct connect...
King-Marqy
Apr 08, 2019Aspirant
Ok, thanks. Here's a drawing:
Site A is connected to B using port 1 and VPN tunnel. New situation must be, no VPN tunnel, direct connection trogh port 4 on modem site A and B (this works, when connecting to port 2 of modem on site B an IP 192.168.178.x is given to my Macbook Pro. Thing is, i've tried to connect port 4 of the modem (patch) to LAN port 2 at site B and configure the SRX for translation... This didn't work, but there is a chance that some VPN tunnel configuration is conflicting with this.. But any config suggestions would be very appreciated. Port LAN2 at Site B has a static IP in the 178 range (192.168.178.253).
JohnC_V
Apr 09, 2019NETGEAR Employee Retired
As per my understanding, you now have 2 ISPs per site and it was connected to the port 4 of the modem going to port 28 of the M4100 switch. What you wanted now is to move your connections to this modem and remove the VPN from the SRX5308. It means that you wanted the fiber connection to be your main line. Is that correct?
JohnCarloV
NETGEAR Community Team
- King-MarqyApr 09, 2019AspirantWell we have fiber as main and cable as backup line. The fiber modem is using port 1 for internet and port 4 for the direct lan connection. Currently VPN tunnel over fiber and if fiber failes over cable. The direct lan connection is however configured by the fiber provider on their modems port 4, so yes we want fiber to be the main line and we also know that if this failes the lan2lan connection won’t work over cable. Thanks for the repelt!
- King-MarqyApr 11, 2019AspirantSituation is going to be different. On site b internet connection is going away, only the lan 2 lan via fiber is going to stay (from a to b).
