King-Marqy
Apr 02, 2019Aspirant
Lan 2 Lan connection setup
Can anybody advise me? We've got two SRX5308 on different sites (A+B). The sites are currently connected using VPN but this is unstable. The provider of the fibre connection has made a direct connect...
King-Marqy
Apr 12, 2019Aspirant
Currently the connection between A and B are active over port 4 of the fibre modem. Discard Site-B's backup ISP (Ziggo), it's not there (mistake). We want to have site A and B connected over the lan2lan connection. Site B will use Site A gateway to the internet. That's all. It would be great if the corp VLAN's could be intact, that means that we don't have to renumber (IP) Site B.
SamirD
Apr 12, 2019Prodigy
By lan2lan connection, are you referring to a vpn tunnel over the fibre connections?
So basically you're just wanting all traffic from site B to go out via site A's connection, correct? Vlans intact if possible?
- King-MarqyApr 12, 2019Aspirant
Thanks for your reply!
No, it's a lan2lan connection (no VPN tunnel). When connecting to modem port 4 on site B it recieves an IP of site A (that works already).
Yes all trafic from B must go to site A, so that:
1) B uses A to go to the internet (site B's own current internet connection is going away, just leaving the direct connection between the modems)
2) Corp netwerk site A must be able to connect to Corp B -> 2 different VLAN's, corp A VLAN 178, corp B VLAN 225, both sites managed VLAN's are 1, both have an additional VLAN for the guest WIFI network: Site A VLAN 165, site B VLAN 235. For the IP range of teh VLAN's see my picture in the other post.
3) Yes VLAN's intact if possible!!! :) it saves renumbering servers, printers and a lot more....
- SamirDApr 12, 2019Prodigy
Okay, so something isn't right here. What are these fibre modems? Because if they connect to the Internet, either they are providing some sort of tunnel between the sites or something else is because you cannot just route packets over the Internet like that unless everything has static Internet IPs.
The fibre modems do have a connection to the internet (port 1 is gateway) and port 4 is configured to each other. The provider has this configured (kind of tunnel?). So port 4 is connected to the switch (VLAN178 untagged) on site A, port 4 on the modem of site B is connected to my macbook pro and i recieve an IP from the DHCP server on site A. A kind of direct connection. So my question is, if I connect the UTP cable from port 4 to the SRX5308, how does the config looks? Do i use LAN port 2 on the SRX or WAN port2 on site B?
