jatman's avatar
jatman
LAN-WAN Throughput on FVS318G-100NAS vs FVS318G-200NAS
Good day,
Can anyone confirm the LAN-WAN throughput on the FVS318G-100NAS and the FVS318G-200NAS models?
I have the FVS318G-100NAS, and the box says LAN-WAN throughput of 25 Mbps.  I have upgraded my internet and can download at speeds in excess of 150 Mbps, but the 100NAS is only averaging 15 Mbps.
From the same supplier that I purchased the FVS318G-100NAS, they are showing another FVS318G with a throughput of 250 Mbps, but it does not state ###NAS so i am not sure if I would be special ordering the old one again.
I would like to confirm that the 200NAS version is capable of 250 Mbps before I confirm the specific model and order it in.
Thank you,
Jat
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi jatman,
    Welcome to the community! :)
    FVS318Gv2 has a LAN-to-WAN Throughput of 250Mbps.  Kindly check page 3 of the data sheet here.
    The product code of FVS318Gv2 in North America is FVS318G-200NAS.  Kindly check page 5 of the data sheet from the link above.
    DaneA
    NETGEAR Community Team
    • jatman's avatar
      jatman
      Hi, and thank you for the response.
      I know what I need, but would you know if the FS318G-200NAS has the feature to filter mac addresses' unless the address is on the allow list.
      Basically, I have a modem from my ISP.  that will connect to the FVS318G-200NAS which will control the entire network and what can access the internet.  I need the 200NAS to deny all mac addresses access to the internet unless it's on the safe list.  I cannot recall the filter featrue name in the 100NAS that i currently use [still at work].  I will update this post when I get home with the feature name.
      thank you,
      • DaneA's avatar
        DaneA
        Hi jatman,
        The FVS318Gv2 supports Source MAC Filtering.  Kindly read pages 196-198 of the FVS318Gv2 reference manual here.
        DaneA
  • Before buying the unit, I would see if anyone has gotten the real-world wan to lan throughput that you need.  Our FVS318Ns top out at just over 60 when they are similarly spec'd much higher (depending on which spec sheet you're reading).
ProSupport for Business
