danlopez
Dec 04, 2017Aspirant
License file
I bought a new laptop and need to move the license to the new laptop, How do I find the license file?
danlopez
Dec 06, 2017Aspirant
I was able to find my old emails with the license files. But I removed the software from one laptop, and I tried both keys and it says the license file is in use. The other license sits on a laptop that is crashed and I can't get it to boot. How do I go about getting the license keys back so I can use them on my new laptops.
Thanks
JohnC_V
Dec 08, 2017NETGEAR Employee Retired
You may need to uninstall it first from the old computer and it should be online while doing this so that it will sync in our database. Then try to install the license to your new PC. Just in case that it would still not work, then you may send the license key and email address to me via pm so that we can reset it for you.
- danlopezDec 08, 2017Aspirant
I pm'd you 2 license files.
Thanks
Dan
- JohnC_VDec 08, 2017NETGEAR Employee Retired
We're now done resetting your license keys. Please check if you can now install it to your new PC.
- danlopezDec 09, 2017Aspirant
I was able to install the license key on the new laptop.
Thank you for your prompt response to this request.
Regards
Dan Lopez
