JimByron
Nov 19, 2019Aspirant
Limit port forwarding to whitelisted IP Addresses
I am looking for a modem/router product recommendation please. I owned a really basic Netgear DG834G modem a few years ago which had a neat Port Forwarding feature which would only port forward f...
DaneA
Nov 19, 2019NETGEAR Employee Retired
Welcome to the community! :)
The BR500 supports both IPSec VPN and Port Forwarding.
Let me share the article below:
How do I set up a site-to-site IPSec VPN on my NETGEAR BR500 Business Router?
About Port Forwarding on the BR500, kindly read pages 136-141 of the BR500 user manual here.
To learn more about the specifications of the BR500, kindly check its data sheet here.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
- JimByronNov 21, 2019Aspirant
Whilst I thank you for your quick reply, you actually didnt answer the question. I know the BR500 has both IPSEC VPN and Port Forwarding because it says so on the sales page, but nothing in that page or the manual you sent indicates whether the port forwarding rule can be enabled ONLY FOR CERTAIN EXTERNAL IP ADDRESSES.. That's the dilemma - I want a router that only forwards traffic that comes from a whitelist of external IP Addresses. Can you confirm this is possible on the BR500?
- DaneANov 21, 2019NETGEAR Employee Retired
As I understand your concern, you wanted to create a port forwarding rule to secondary WAN IP addresses, am I right? If yes, I regret to inform you that this is not possible on the BR500.
DaneA
No, I dont think you understood. I want to create a port forwarding rule which only works for a list of external IP addresses. In other words, if a user at an address with a "trusted" IP address tries to access the server using remote desktop port 3389, they will be forwarded to the server, but if someone at any other IP address tried, the forward will fail
