morrisonkena
Sep 22, 2015Aspirant
Mac OS X Yosemite VPN setup
I have a Netgear FVS336G3 VPN Firewall set up as my home internet gateway, patched to current version. While my ISP does not issue a fixed IP address, the address issued is static until the firewall ...
Retired_Member
Sep 26, 2015morrisonkena -
I recommend using vpntracker. I had initial success with the securitas software, but I could NEVER get it to work consistently. One thing that you could try is Parallel's (Windows VM). I've been able to get the Netgear VPN client to work via Parallels. Just change the network settings.
- DaneASep 27, 2015NETGEAR Employee Retired
Hi BrunoCorazon,
Thanks for sharing your experience to the community! :smileyhappy:
Can you enumerate the steps as well as post screenshots on how did you make both VPNtracker and Parallels worked?
DaneA
NETGEAR Community Team- Retired_MemberSep 27, 2015
Sorry no screenshots.
For Parallels, check their Knowledge Base.
http://kb.parallels.com/en/4948
https://forum.parallels.com/threads/use-vpn-connection-in-osx.328552/
For vpntracker, just follow the instructions.
http://download.equinux.com/Manual_VPN_Tracker_8.1.4.pdf
The only time I've had issues or problems is when there's been a host-based firewall. McAfee and Norton are not a problem. AVG takes some serious tweaking because of its granularity.
