morrisonkena
Sep 22, 2015Aspirant
Mac OS X Yosemite VPN setup
I have a Netgear FVS336G3 VPN Firewall set up as my home internet gateway, patched to current version. While my ISP does not issue a fixed IP address, the address issued is static until the firewall ...
DaneA
Sep 27, 2015NETGEAR Employee Retired
Hi BrunoCorazon,
Thanks for sharing your experience to the community! :smileyhappy:
Can you enumerate the steps as well as post screenshots on how did you make both VPNtracker and Parallels worked?
DaneA
NETGEAR Community Team
Retired_Member
Sep 27, 2015Sorry no screenshots.
For Parallels, check their Knowledge Base.
http://kb.parallels.com/en/4948
https://forum.parallels.com/threads/use-vpn-connection-in-osx.328552/
For vpntracker, just follow the instructions.
http://download.equinux.com/Manual_VPN_Tracker_8.1.4.pdf
The only time I've had issues or problems is when there's been a host-based firewall. McAfee and Norton are not a problem. AVG takes some serious tweaking because of its granularity.
