RRHNL
Mar 10, 2018Initiate
Memory leak
I have located a Memory leak in my system associated with the following Greenbow driver(s) with tags identified via Poolmon.exe as TgBj and TgBi. I have windows 10, 64bit. These drivers are filling up my 16GB of nonpooled page memory until my system crashes after abount 48 hours. Please can you fix.
Here is the offending driver.
TGBVPNVirtM.sys
Here is a snapshot of the Poolmon.exe on my system - I cannot identify the Mdl tag as there are too many drivers with the string mdl included.
Memory:16670352K Avail: 9342524K PageFlts: 145 InRam Krnl:29348K P:824300K
Commit:8410120K Limit:17489552K Peak:11698320K Pool N:1446384K P:858924K
System pool information
Tag Type Allocs Frees Diff Bytes Per Alloc
Mdl Nonp 492168 ( 0) 38836 ( 0) 453332 94635472 ( 0) 208
TgBj Nonp 449217 ( 0) 0 ( 0) 449217 273124864 ( 0) 608
TgBi Nonp 2717774 ( 0) 2268571 ( 0) 449203 80128128 ( 0) 178
FMfn Paged 24716372 ( 124) 24408994 ( 121) 307378 147898240 ( 1584) 481
CFFE Nonp 1413328 ( 0) 1126751 ( 0) 286577 125768768 ( 0) 438
NtFs Paged 2688730 ( 0) 2574271 ( 0) 114459 21974176 ( 0) 191
File Nonp 7328471 ( 20) 7259783 ( 19) 68688 27451968 ( 400) 399
- mattcozAspirant
I have this exact same problem! Were you ever able to find an update?
- RRHNLInitiateNo. Netgear support didn’t respond as I had hoped. They offered to work with me to get connected which was not the issue, and wanted me to do copious testing to which I declined as I am now CFO of a company (with some old IT knowledge) & I wanted them to research & fix. So all I do now is watch my non paged pool and when it gets to around 3-4gb I reboot. I also exit my rdp session on the remote computer when I’m done and sometimes close the tunnel. This stops the leak from growing overnight eg. Overall I wish they would patch & fix, but they didn’t seem interested enough or didn’t understand the issue was that I was reporting a flaw.
- mattcozAspirant
Damn. I think we're better off going through Greenbow as it is their driver that is causing the problem. Netgear is just licensing it for their use. I downloaded their latest version which had a slightly newer driver and I'm doing some testing. So far my NP pool hasn't grown to immense size, but those tags are still at the top and growing.
