Makookam
Jul 09, 2018Aspirant
My Firewall limited download/upload to 60/60 Mbps without my interference
Hello all,
I have a problem with my broadband speed. I plug cable directly to router - I reach 1Gbps/100Mbps.
If I plug cable to firewall I reach 60/60Mbps.
Few days ago everything was OK. ...
JohnC_V
Jul 13, 2018NETGEAR Employee Retired
Hi Makookam,
Welcome to our community! :)
FVS318N can only handle upto 250Mbps LAN-to-WAN throughput. It is limited to that bandwidth. If you do have 1Gbps/100Mbps then it cannot be handled by the FVS318N but it will be maxed out to its limit. You may try resetting it to factory default.
Here is the reference.
Makookam
Aug 06, 2018Aspirant
I did reset to factory default and restore from backup. After few days problem's back again.
Now (after reboot, not restore!) FVS318N reached 600/100.
What more can I do?
