1y0fms
Nov 19, 2016Aspirant
Microwave Interference
Model WNDR3400v3 Firmware V1.0.1.4
The microwave keeps interfering. I have the channell selction at auto. Often it is on Ch 8.
What can I do to eliminate microwave interference??
yeah . . say, i did try chnaging to ch 1. We will see how that goes in the next day or 2. OK?? I mean if I could switch to 5 Ghz that would be great .. but I did chnage the channell. I noticed all my neighbors are normally between 6 and 8. So I will give 1 a try . .
Your WNDR3400 is a dual band router, so switch any devices to 5 GHz, if they are capable. Microwave ovens nominally operate around 2.45 GHz, which is around channel 8. Try using channel 1, provided that it's not too heavily used by neighboring Wi-Fi networks.
- 1y0fmsAspirant
What do you mean by switch any devices to 5 Ghz?? I guess I cant do that because it is interfering with the wifi going to my ROKU. This makes it so I cant use the microwave and the ROKU at the same time. I will try chnaging to ch 1 as you sugested. I just hope it will work good enough for the rOKU.
Your WNDR3400 has two Wi-Fi networks, one that broadcasts in the 2.4 GHz band and another in the 5 GHz band. Many devices, such as laptops and smartphones are capable of operating in either of these frequency bands. My suggestion was for you switch those devices to use the 5 GHz network. If the 5 GHz network is not enabled in your WNDR3400, then turn it on and set a Wi-Fi password on it.
What's the model of your Roku? Some of their models can operate at 5 GHz.
