IanB-CDS's avatar
IanB-CDS
Need to reset VPN client license
Hi, I need to reset my VPN client license so that I can use it on a different laptop. Previous laptop is no longer in circulation.
  • JohnC_V's avatar
    Aug 12, 2017
    Hi IanB-CDS,
    Welcome to the community!
    Please uninstall the client first from the previous PC before installing it and make sure that you are connected to the internet so that it will automatically updated in our database, same as resetting the license key on our end.
    If it did not work, then please send me the license key via pm.
ProSupport for Business
