viper488
May 15, 2017Aspirant
Need VPN Client License Key Reset
Hi, I recently re-imaged my windows laptop where the VPN Client software was actived. Now that the laptop has been re-imaged, I can not use the same VPN license since it gives gives me an error stati...
DaneA
May 16, 2017NETGEAR Employee Retired
Hi viper488,
Welcome to the community! :)
Kindly send me the following below via private message:
a. the VPN license key that needs to be reset
b. e-mail address that was used when you have registered the VPN license key
DaneA
NETGEAR Community Team
DaneA
May 17, 2017NETGEAR Employee Retired
I got your private message and inquired it to a higher tier of NETGEAR Support. It was found out on their end that you just got the VPN license key activated on the same machine today.
DaneA
- viper488May 17, 2017Aspirant
DaneA
Thanks, was able to get the license working. Appreciate the help!
