viper488
May 15, 2017Aspirant
Need VPN Client License Key Reset
Hi, I recently re-imaged my windows laptop where the VPN Client software was actived. Now that the laptop has been re-imaged, I can not use the same VPN license since it gives gives me an error stati...
DaneA
May 17, 2017NETGEAR Employee Retired
I got your private message and inquired it to a higher tier of NETGEAR Support. It was found out on their end that you just got the VPN license key activated on the same machine today.
DaneA
NETGEAR Community Team
viper488
May 17, 2017Aspirant
DaneA
Thanks, was able to get the license working. Appreciate the help!
