PIAC
May 23, 2024Aspirant
Need VPN Prosafe License key reset
My old laptop with a VPN Prosafe VPN client installed died and I need to install the client on the new machine. I can't uninstall as requested and upon reinstalling it says all licenses are used. Is ...
PIAC
Unfortunately, I do not own a PR60X router. We are currently using an old NETGEAR FVS338. Others in the community over the years have had difficulty configuring the windows built-in VPN to connect to this router. Is there any guidance you can point me at to do this or are you suggesting the solution is to purchase new routers.
Thanks for your response!
op3c
May 23, 2024NETGEAR Expert
Let me check if our QA can come up instructions for using OS built-in client to connect to FVS338. Will forward step by step instructions to you if our QA can make it work. Thanks.
