Coop59's avatar
Coop59
Netgear Firewall
Hello Everyone,
         I am realitively new to the netgear community, I have always just bought unmanaged switches up to this point and been happy with them because I didn't know any better. I recently purchased a Netgear FVS336G and I have searched high and low for a tutorial or step by step to show me how to configure the firewall. Nothing of any substance has been found to this point.
I also bought 2 JGS524Ev2 - 24-Port switches, these things from what I can tell are outstanding. So I have figured out how to create VLANs (Great Tutorials for this) on all the devices and I am able to connect to the different ports and get an IP from the DHCP servers I set up on those VLANs via the router/firewall.
If anyone could point me to good firewall tutorial for the FVS336G or this type of firewall it would be appreciated. And please don't send me a tutorial for a home router. This is a business class router.
Thanks again,
Michael
  • schumaku's avatar
    schumaku
    Michael,
    Hope you have not paid a fortune for this FVS336G - these routers are EoL for a longer time already.
    "Netgear will terminate the ProSAFE VPN Firewalls on September 1, 2017. The last software update for these products was provided in April 2017. NETGEAR Inc. will continue to honor valid warranty claims for all ProSAFE VPN Firewall devices purchased from an authorized reseller. To complete the full exit from the product line, NETGEAR Inc. will no longer provide ProSAFE VPN Firewall software support or subscription updates for any ProSAFE VPN Firewall devices after September 1, 2017."
    • Coop59's avatar
      Coop59
      I paid 50 dollars for it, and it seems to be very stable.
      schumaku wrote:
      Michael,
      • tetrawest's avatar
        tetrawest
        Apprentice
        They are very good machines. Which version of the FVS336 are you using? There should be a little v at the end of he model with a number, like 2 or 3.
        The FVS336 will certainly be better than nothing. You have the links to the manuals on setup and port configurations.
        I ran first FVS336v2 then FVS336v3 for many years. The v3 does seem to have an issue with creating problems with my 8x8 VOIP phones. This did not exist with the v2. The big difference between v2 and v3 is the WAN throughput, which I think was 25Mbps on the v2.
        I do wish that NETGEAR would give out the firmware so that third party groups could potentially support the devices.
ProSupport for Business
