migie58
Oct 30, 2016Aspirant
NetGear FVS 318N WAN throughput limited
I have read the other posts and also performed the recommended actions, but I am also experiencing limited throughput on my firewall. I recently upgraded my TWC to Spectrum Internet. The service conn...
JohnRo
Nov 02, 2016NETGEAR Employee Retired
Hello migie58,
Welcome to the community!
At this point, it is best to contact our Support Team and have them take a look at your settings. If your FVS318N is running on factory defaults and you are getting a very low bandwidth then there is something wrong with the router. I believe you mean Mb instead of Gb for the UL and DL speeds.
Thanks,
