danieljgor
Jun 08, 2016Aspirant
Netgear FVS318G 8 port wired router PORT FORWARDING NIGHTMARE
Hi Guys, Hope you can help me with my Port forwarding issue. I have a Netgear FVS318G 8 port wired router with Firmware Version 3.1.1-18 (latest) I have spent hours in trying to setu...
- Jun 16, 2016
Hi danieljgor,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
JohnRo
Jun 08, 2016NETGEAR Employee Retired
Hello danieljgor,
Welcome to the community!
My opinion on this is unless the ports 8078 and 8077 are defined on the camera(s) this is not going to work. I am thinking all if the three cameras are using port 80 for web access. My suggestion is to use "Translate to port number", edit the rules you have created for camera 2 and 3. See image reference below:
Let us know if this helps.
Thanks,
