danieljgor
Jun 08, 2016Aspirant
Netgear FVS318G 8 port wired router PORT FORWARDING NIGHTMARE
Hi Guys, Hope you can help me with my Port forwarding issue. I have a Netgear FVS318G 8 port wired router with Firmware Version 3.1.1-18 (latest) I have spent hours in trying to setu...
- Jun 16, 2016
Hi danieljgor,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
danieljgor
Thank you for your response.
When pinging the port they are closed even after rules are setup in router.
Only port open is port 80 when setup as http
Thoughts??
Thanks
Daniel
Thoughts??
Thanks
Daniel
JohnRo
Jun 09, 2016NETGEAR Employee Retired
Hi Daniel,
Can you PM e a screenshot of your Inbound Rules? Did you try my suggestion to use Translate to port number?
Thanks,
- danieljgorJun 11, 2016Aspirant
Hi Guy's,
Sorry about the delay.
It does work when translating all ports to port 80.
What issue can this cause?
Odd that you can simply open ports!
Thanks
Daniel
- JohnRoJun 13, 2016NETGEAR Employee Retired
Hello danieljgor,
This confirms my suspicion, you can open the cameras by translating to port 80 because only port 80 (HTTP) is defined on your cameras. If you can change the ports the camera(s) are using then there is no need to translate.
Thanks,
- JohnRoJun 16, 2016NETGEAR Employee Retired
Hi danieljgor,
- JohnRoJun 20, 2016NETGEAR Employee Retired
Hi Daniel,
You're welcome! Feel free to open a new post if you have any concerns. I am not sure what survey you are referring to.
Thanks,
JohnRo
