mtalent
Mar 18, 2017Follower
netgear fvs318gv2 setup in office with 2 lans and 5 static ip's
Originally we had a 24 port unmanaged switch with a active directory domain controller/dhcp that handled all of the office staff. There was one static ip that was used for a vpn with port forwarding...
SamirD
Mar 19, 2017Prodigy
I think the slowness locally might have been somehow caused by a reverse dns lookup or something of that nature. That's the only thing I know of that might take that type of time. Or something else that was timing out.
As far as your configuration, a diagram would help a lot to understand what you had that wasn't working and what you did that did work. My hunch is that your working setup could be done a little 'neater' but I don't really know without seeing the network map.
