samuelk
Jul 31, 2019Aspirant
netgear prosafe srx5308
hello everybody first of all i thank all of you helping out here. i m new using the netgear and i have netgear prosafe gigabit quad wan ssl vpn firewall srx5308. i would like to see all the at...
- Aug 01, 2019
Hi samuelk,
Welcome to our community! :)
To view the network database, select Network Configuration > LAN Settings > LAN Groups. It takes some time to load depending on the number of devices connected to your network.
Here is the reference manual(page 97).
If ever your concern has been addressed or resolved. You may close the thread by clicking the "Accept as Solution" so others can be confident on benefiting from the solution.
JohnCarloV
NETGEAR Community Team
JohnC_V
Aug 01, 2019NETGEAR Employee Retired
Hi samuelk,
JohnCarloV
