Teknikforlaget
Jun 01, 2016Aspirant
NETGEAR ProSafe VPN Firewall FVS338 – Nighthawk X6
Dear Netgear community! We have decided to upgrade our router after a long time of very faithful service. – Our current router is NETGEAR ProSafe VPN Firewall FVS338 – We will get the Netgear ...
- Jun 01, 2016
Teknikforlaget wrote:
is it possible to use the backup preference file exported from the FVS338 and then import it into the new Nighthawk X6?
The config files aren't compatible, so you will need to reconfigure.
The Nighthawk routers include openvpn support (at least the R7000 and R8500 do), so it is different from the FVS338. You'll need the openvpn app on the PCs and mobile devices. You download the config file from the router admin page.
Jun 01, 2016Guru - Experienced User
- TeknikforlagetJun 01, 2016Aspirant
Dear Stephen!
Thanks a lot for your prompt reply. I guess we´ll have to reconfigure the whole thing and I guess it could be done through a browser?!
Im on a mac and I use the IP Securitas client to access the network remotely.
Best,
Tom
- DanthemJun 01, 2016NETGEAR Employee Retired
Hej!
Worth noting is that the Nighthawk would be considered a home unit, if you want to go down the business line I'd recommend going for a FVS336Gv3 instead. It has two WAN ports and can do IPSec VPN , PPTP, L2TP and SSL VPN (I recommend IPSec though).
-Danthem
edit; you still wouldn't be able to transfer to config file over, but the settings on the FVS336Gv3 would be similar to the FVS338 so you'd know what to look for :).
