slows4
Apr 01, 2022Aspirant
Netgear SRX5308 License Key
This was purchase as an site to site option for our servers in a colocation abroad. Over the years it has served its purpose. Now the site to site was paired with a sonic wall firewall on the other e...
adv
Apr 02, 2022Aspirant
Have you installed a SSL certificate on it? If so, can you give me some help with mine? See my topic "ProSafe SRX5308 Certificate creation". Thanks.
slows4
I have not, but I am sure that it isn't too hard of a task? Are you just trying to apply it?
- advApr 02, 2022Aspirant
Yes, I am start9nh with creating a trusted root certificate with my own OpenSSL authority on a Linux box and getting that to load but no luck. I have tried several different options and done hours of searching. I found that it will only handle MD5 or SHA1 and 2048 max and also that the ST (State or Province) parameter is not handled so cannot be included. I created the CA but I cannot get the root certificate to load into the trusted certificates. I don't know if it will accept a .pem file or if it needs a .crt or something else or if there are other requirements I am missing. The possibilities are many but there is NOTHING in the manual about what format and parameters are required.
