Jammmer
Jul 29, 2018Follower
Netgear VPN Client Activation on another computer
Hi there,
I see a few of these - I have the same problem.
I have a few VPN Client licenses that won't activate because I have lost the original computers they were installed on due to hard di...
DaneA
Jul 29, 2018NETGEAR Employee Retired
Hi Jammmer,
Welcome to the community! :)
Kindly send me the following below via private message:
a. the VPN license key that needs to be reset
b. the e-mail address/es that was used when you have registered the VPN license key
DaneA
NETGEAR Community Team
- DaneAJul 30, 2018NETGEAR Employee Retired
I got a feedback from the higher tier of NETGEAR Support that all of your VPN license keys has been reset. Kindly try to register it on your computers.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
