a-hua
Feb 05, 2018Aspirant
Netgear VPN Client Active problem
Hi Support, I have a FVG318v2 firewall with one license vpn client embedded. It is found that I can't active the vpn client on my new laptop because I forgot to remove it from my old laptop. Coul...
JohnC_V
Feb 06, 2018NETGEAR Employee Retired
Hi a-hua,
Welcome to our community!
May you be able to send it to me via pm the license key and the email used in it?
a-hua
Feb 06, 2018Aspirant
Hi,
License key: 553330-*****-****-*****
Email: edward.999@********.com
Thanks.
A-Hua
- JohnC_VFeb 07, 2018NETGEAR Employee Retired
You should've sent it via private message so it will keep you private and the license key won't be taken away from you. I just edited your post.
Let me try if we can now reset it.
- a-huaFeb 07, 2018Aspirant
Hi Support,
The vpn client has working properly, thanks.
A-Hua
