a-hua's avatar
a-hua
Netgear VPN Client Active problem
Hi Support,   I have a FVG318v2 firewall with one license vpn client embedded. It is found that I can't active the vpn client on my new laptop because I forgot to remove it from my old laptop. Coul...
  • JohnC_V's avatar
    JohnC_V
    Feb 07, 2018
    a-hua,
    You should've sent it via private message so it will keep you private and the license key won't be taken away from you. I just edited your post.
    Let me try if we can now reset it.
ProSupport for Business
