pkbothers's avatar
pkbothers
Nighthawk X8 R8500
I have: 1. Motrola SB183 2. NETGEAR ProSAFE GS116NA 16-Port Gigabit Ethernet Switch (GS116NA)                               3. Netgear nighthawk X8 4. NETGEAR ProSAFE GS108 8-Port Gigabit Desktop...
  • JohnRo's avatar
    JohnRo
    Jun 10, 2016
    Hi pkbothers,
    No, there shouldn't be and loss unless you have a ton of Firewall Rules created on the router. The switches do not really affect your internet bandwidth so adding Gigabit switches will not speed up your internet. Just like what I have mentioned, the setup will not work since the switches do not have the capability to create their own network that is why they need to be behind the Router (which is the DHCP server).
    Thanks,
ProSupport for Business
