dunk2710
Nov 10, 2016Aspirant
Port Configuration
Hi Guys. I've recently took over an IT job and I'm a little bit confused as how our firewall router is setup. It shows each port as as the same IP, but on the VLANs page it sh...
Dan_Z
Nov 10, 2016NETGEAR Expert
Hi dunk2710,
Welcome to the community!
Port2 show the network as 192.168.0.1,because the default vlan of port2 is vlan1.
Please go to "Network Configuration->LAN Settings->LAN Setup",check the Default vlan.
Change default vlan to Guest for port2.
Thanks
Dan
- dunk2710Nov 11, 2016Aspirant
Hi Dan!
thanks for your answer.
From what you're saying, this would mean that the IPv4 address (192.168.0.1) has no bearing on Port 2 since the VLAN has a completely different IP (11.1.1.1)? I can see on the Network Config > Lan settings > LAN setup page that all ports have their default VLAN set to "DEfault":If I were to tidy this up and change port 2 to the proper VLAN name would this affect network connectivity?
- Dan_ZNov 13, 2016NETGEAR Expert
Hi dunk2710,
If you want to use Guest vlan 88 for port2,need to edit port2 default vlan to Guest.
Now,the port2 is belong to vlan 1.
After change it,the port2 will belong to vlan88 with the ip address 11.1.1.1.Thanks.
- dunk2710Nov 15, 2016Aspirant
Dan:
That's my point, Port2 already uses VLAN 88 as our Guest WiFi goes out via this port and I can confirm that this network (vlan 88 - 11.1.1.1) is functioning.
