Theok's avatar
Theok
Tutor
Apr 04, 2022
Help with firewall configuration - Port forwarding/port triggering
Hi, wondering if somone could let me know if I should be trying to configure port forwarding or triggering with the following instructions.  Any help/guidance would be appreciated.  I'm assuming I need to do one for each of them with multiples where there are TCP and UDP and also multiple IP addresses, etc.  Router is SRK60, Orbi Pro AC3000.
Thanks very much in advance (hopefully).
  • None required - anything on the list are the required outgoing connections (Source device LAN IP). If you operate on a very strict firewall environment you would have to allow the listed LAN-> Internet configs.
  • schumaku's avatar
    schumaku
    All the source and destination IPs for the ports listed are outgoing LAN > WAN/Internet. These are not NAT port forwardings - for the obvious reason when operating more than one phone this would be simply impossible.
    • Theok's avatar
      Theok
      Tutor
      schumaku, based on the document and the forward/trigger screen, could you provide a little guidance/example of the settings for one of them?
      Thanks!
      • schumaku's avatar
        schumaku
ProSupport for Business
