Theok
Apr 04, 2022Tutor
Help with firewall configuration - Port forwarding/port triggering
Hi, wondering if somone could let me know if I should be trying to configure port forwarding or triggering with the following instructions. Any help/guidance would be appreciated. I'm assuming I ne...
- Apr 07, 2022None required - anything on the list are the required outgoing connections (Source device LAN IP). If you operate on a very strict firewall environment you would have to allow the listed LAN-> Internet configs.
Theok
Apr 07, 2022Tutor
schumaku, based on the document and the forward/trigger screen, could you provide a little guidance/example of the settings for one of them?
Thanks!
schumaku
Apr 07, 2022Guru - Experienced User
- TheokApr 07, 2022Tutor
Thanks! Will try setting them up and hopefully that's it.
