Moonan9's avatar
Moonan9
Follower
Nov 24, 2015
Port Forwarding stops working on port 443 on FVS318G
Hello,
I have an issue whereby i have only to port forwarders enabled, Port 3389 and port 443.
Port 3389 works perfectly fine no hassles. However port 443 keeps on closing or does not port forward. It works for about max 4 hours then stops port forwarding.
Here is what i have tried:
Upgrade bios to latest 3.1.1-18
Disable the stealth mode
Remove and readd the port 443 forwarder
Hard reset the firewall
Enable and disable secure remote management with various ports
Tick and untick trasnlate to port number under inboude service rule
User different external IPS for the port forwarder
Tried setting the rule in DMZ WAN rules
Please help what else can i try
Thanks
Warren
No RepliesBe the first to reply
ProSupport for Business
