hgwd
Feb 17, 2013Follower
Port Forwaring on FVS336G
I am having problems setting up port forwarding on this router. Basically from outside the network when I go to the routers IP on port 86 I want that to route internally to 192.168.0.38:86 so ...
jmizoguchi
Feb 17, 2013Virtuoso
You do not need to use port translation on some ports
If you have service port created 86 then translation is not need it
Make sure WAN of the FVS has public IP
