alex_Regis
Mar 17, 2014Aspirant
Port Not Open
Hi,
I have a Netgear FVS318G. It is behind a Comcast router set in bridge mode.
I can not access Port 143 for IMAP, for email.
I have the port open on the firewall. I can not telnet into that port from outside my network. Internally I can access the port.
Other ports that I have opened on my firewall are working.
Any ideas?
Any ideas?
- jmizoguchiVirtuosoNone are blocking so should work
http://customer.comcast.com/help-and-support/internet/list-of-blocked-ports/
If other ports is working then reason not to.
Telnet is for the router or the LAN device? - alex_RegisAspirantI telnet into my mail server to see if I could connect to IMAP through port 143. Worked internally. It should also allow me to do this externally, it did not.
I have quite a few ports open, does the quantity or place in the list of open ports have any effect?
Thanks for the help. - aditMentorRules are processed top down. Check software firewall.
- alex_RegisAspirantAre you suggesting that I move my port 143 rule to the top of the list?
I do not have any software firewall on the mail server. - aditMentorIf you only have 1 IMAP Rule it does not matter. Default gateway correct on the server?
- alex_RegisAspirantI only have the one IMAP rule.
The gateway on the server is correct.
I have a POP3 rule that works.
Is their a limit to how many firewall rules you can have? - jmizoguchiVirtuosoShould easily handle 15-20 rules
I don't remember if this model has telnet feature but make sure disable it if it does - aditMentorAre you using the pre-defined IMAP Service or did you create a custom one?
- alex_RegisAspirantI am using the predefined IMAP rule.
I have 15 active rules. - aditMentorWhich firmware is on the router? Post a screenshot of your Rules.
