Axxe11
Mar 14, 2017Aspirant
Port redirection on FVS336V1
I'm upgrading from a Draytek Vigor 2800 Router to a netgear FVS336GV1 Firewall. On the Draytek, the Port Forwarding setup allows me to set different public and private ports - for example, I have incoming WAN traffic on Port 2500, but I redirect that to Port 25 on a private IP. I also have several devices on different private IP addresses, which I want to access on the private port 80 - with the Draytek, I have incoming connections on different port numbers (eg 8070, 8080, 8090, etc.) which redirect to port 80 on different private IP addresses.
I can't see a way to replicate this configuration on the Netgear - Port Redirection only allows me to specify an incoming port and a private IP.
Hello Axxe11,
Welcome to the ciommunity!
You can do by going into the Firewall Inbound Rules then choose the port you'll want to use. See image below:
Please see page 66 of the User manual for the description.
Thanks,
- JohnRoNETGEAR Employee Retired
Hello Axxe11,
Thanks,
