jimbo67
Sep 29, 2024Aspirant
PR60X Managing hosts file
Hello, for some reasons i would need to update the hosts file of the touteur ( cannot access lan website using names and ssl with wireguard since i left cloudflare for a cheaper solution ). But ...
jimbo67
I found the answer myself https://kb.netgear.com/000049578/What-is-NAT-loopback-and-which-NETGEAR-routers-support-NAT-loopback
- jimbo67Sep 29, 2024Aspirant
And then https://kb.netgear.com/000066031/How-do-I-enable-NAT-loopback-on-my-PR60X-or-PR460X
Well kinda strange but it works after i moved the web server port from the mx510txp to one of the pr60x port.
And without the loopback i had lost insight mangement too. I just realised when the blue light came back after switch the port.
Anyway would be so much easier to be able to update hosts from web interface.
- jimbo67Sep 30, 2024Aspirant
Well i was wrong it solved one part of the problem as accessing local somme application using port 443 on server pinpointing to wan adress.
But since i used ip filtering to access toses server it doesnt work when i tried to access them using vpn I tried ipsec,openvpn and wireguard but none can access those url.
