jimbo67
Sep 29, 2024Aspirant
PR60X Managing hosts file
Hello, for some reasons i would need to update the hosts file of the touteur ( cannot access lan website using names and ssl with wireguard since i left cloudflare for a cheaper solution ). But ...
jimbo67
Sep 30, 2024Aspirant
Also everything works fine from wan.
But i wan to acess it using vpn connected to the phones.
Yet my workaround is to access it using auth method throught https with a nginx proxie to redirect.
I can also use the vpn and access ressources with ip.
But i would prefer to acess it with the vpn using https with domain name.
Yea i know its absolutly overkilll and useless.
I dont want to start modify Android or Apple config file just for that.
c3po2
Sep 30, 2024Apprentice
Thank you for detailed description, we will try to setup same network as yours to see if we can make improvements for your application.
- jimbo67Oct 08, 2024AspirantI modified the /etc/hosts file to match my domainename.eu on the server i use as the dns proxy running for local.
Than forced the router to use it to enjoy the loopback ability of the router.
It works fine using this setup but still not while using the vpn.
Only solution yet is to use cloudflare dns proxies to acess those domain with the vpn.
Well i'm not trying anymore to make the vpn work to access my domainname using my sertigo ssl on my services localy hosted.
