Insightava
Apr 08, 2024Aspirant
PR60x NAT
Using a PR60x and can't change the NAT from secured to open - can somebody point me to where this is located in the settings...please? Thanks in advance
Apr 11, 2024Guru - Experienced User
I know on home class NG routers, NAT Filter located under Advanced Tab/Setup/WAN Setup is where you can change from Secure to OPEN. Not sure if the PR series has this feature. Look around the WEB UI for something NAT Filter and see. I presume if you don't see this feature on the PR, then maybe something not supported. Most Nighthawk and Orbi home class systems has this feature.
Thanks in advance
