jimbo67's avatar
jimbo67
PR60X WireGuard adding external peer such as Proton
Wireguard "server" works like a charm. Is it even possible to connect the server to another server as peer? The idea would be to have wifi guest on a vlan using proton CH wireguard "server", 3/4 An...
  • BrianL's avatar
    BrianL
    Oct 07, 2024
    Hi jimbo67,
    A feature request has been created by my colleague. Hopefully, this can be added as a feature soon.
    Thank you for choosing NETGEAR!
    Kind regards,
    BrianL
ProSupport for Business
