dfos27
Sep 06, 2023Follower
PR60X/PR460X Client VPN Capable or Site to Site only?
Was going through the product spec sheet(s) and the documentation for the PR60X/PR460X and noticed in the manual that it states it provides site to site VPN IPSec but does NOT provide remote client V...
jakcyc
Dec 04, 2023Initiate
I was having the same question, and was looking at the user manual, which found that was being mentioned on page 146.
Note:The router does not support client-to-gateway connections, where by a computer or mobile device of a remote user connects through a VPN tunnel directly to a VPN router. The router supports site-to-site connections between two NETGEAR VPN routers or between a NETGEAR VPN router and a third-party VPN router.
https://www.downloads.netgear.com/files/GDC/PR60X/PR60X_UM_EN.pdf
