Bornfree's avatar
Bornfree
Problems with FVS336GV2 and AVAYA 9620L VPN
Hi There,
I'm having problems setting up my avaya 9620L VPN phone with my netgear FVS336GV2. I'm sure i have all the config correct as i have checked it a million times. This thing was working before and for some reason the phone lost all its setting so now the phone is with me. I have 2 different internet connections so the pbx is on one internet the VNP phone on the other. Below is the VPN log from my netgear. any help is appericated.
Also you can see the time is not correct and i'm not able to fix this problem.
1970 Jan  1 11:21:39 [FVS336GV2] [IKE] Remote configuration for identifier "vpn" found_
1970 Jan  1 11:21:39 [FVS336GV2] [IKE] Received request for new phase 1 negotiation: 27.0.4.12[500]<=>203.26.17.4[2070]_
1970 Jan  1 11:21:39 [FVS336GV2] [IKE] Beginning Aggressive mode._
1970 Jan  1 11:21:39 [FVS336GV2] [IKE] Received unknown Vendor ID_
1970 Jan  1 11:21:39 [FVS336GV2] [IKE] Received Vendor ID: draft-ietf-ipsec-nat-t-ike-02__
                - Last output repeated 2 times -
1970 Jan  1 11:21:39 [FVS336GV2] [IKE] Received Vendor ID: draft-ietf-ipsra-isakmp-xauth-06.txt_
1970 Jan  1 11:21:39 [FVS336GV2] [IKE] For 203.26.17.4[2070], Selected NAT-T version: draft-ietf-ipsec-nat-t-ike-02_
1970 Jan  1 11:21:39 [FVS336GV2] [IKE] Setting DPD Vendor ID_
1970 Jan  1 11:21:40 [FVS336GV2] [IKE] Floating ports for NAT-T with peer 203.26.17.4[4500]_
1970 Jan  1 11:21:40 [FVS336GV2] [IKE] NAT-D payload matches for 27.0.4.12[4500]_
1970 Jan  1 11:21:40 [FVS336GV2] [IKE] NAT-D payload does not match for 203.26.17.4[4500]_
1970 Jan  1 11:21:40 [FVS336GV2] [IKE] NAT detected: Peer is behind a NAT device_
1970 Jan  1 11:21:40 [FVS336GV2] [IKE] Sending Xauth request to 203.26.17.4[4500]_
1970 Jan  1 11:21:40 [FVS336GV2] [IKE] ISAKMP-SA established for 27.0.4.12[4500]-203.26.17.4[4500] with spi:767625ff13d37354:b14cd6f4e4086e76_
1970 Jan  1 11:21:40 [FVS336GV2] [IKE] Received attribute type "ISAKMP_CFG_REPLY" from 203.26.17.4[4500]_
1970 Jan  1 11:21:40 [FVS336GV2] [IKE] Login succeeded for user "SPE"_
1970 Jan  1 11:21:40 [FVS336GV2] [IKE] Received attribute type "ISAKMP_CFG_REQUEST" from 203.26.17.4[4500]_
1970 Jan  1 11:21:40 [FVS336GV2] [IKE] 172.16.22.101 IP address is assigned to remote peer 203.26.17.4[4500]_
1970 Jan  1 11:21:40 [FVS336GV2] [IKE] Ignored attribute 5_
1970 Jan  1 11:21:40 [FVS336GV2] [IKE] Ignored attribute 6_
1970 Jan  1 11:21:42 [FVS336GV2] [IKE] Responding to new phase 2 negotiation: 27.0.4.12[0]<=>203.26.17.4[0]_
1970 Jan  1 11:21:42 [FVS336GV2] [IKE] Ignore INITIAL-CONTACT notification from 203.26.17.4[4500] because it is only accepted after phase1._
1970 Jan  1 11:21:42 [FVS336GV2] [IKE] Using IPsec SA configuration: 192.168.3.0/0<->172.16.22.0/24_
1970 Jan  1 11:21:42 [FVS336GV2] [IKE] Adjusting peer's encmode 61443(61443)->Tunnel(1)_
1970 Jan  1 11:21:43 [FVS336GV2] [IKE] IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 203.26.17.4->27.0.4.12 with spi=134913184(0x80a9ca0)_
1970 Jan  1 11:21:43 [FVS336GV2] [IKE] IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 27.0.4.12->203.26.17.4 with spi=1608207363(0x5fdb4c03)_
1970 Jan  1 11:21:52 [FVS336GV2] [IKE] an undead schedule has been deleted: 'pk_recvupdate'._
1970 Jan  1 11:21:52 [FVS336GV2] [IKE] Purged IPsec-SA with proto_id=ESP and spi=1608207363(0x5fdb4c03)._
1970 Jan  1 11:21:55 [FVS336GV2] [IKE] Purged ISAKMP-SA with proto_id=ISAKMP and spi=767625ff13d37354:b14cd6f4e4086e76._
1970 Jan  1 11:21:56 [FVS336GV2] [IKE] ISAKMP-SA deleted for 27.0.4.12[4500]-203.26.17.4[4500] with spi:767625ff13d37354:b14cd6f4e4086e76_
1970 Jan  1 11:21:57 [FVS336GV2] [IKE] 172.16.22.101 IP address has been released by remote peer._
  • JohnRo's avatar
    JohnRo
    NETGEAR Employee Retired
    Hello Bornfree,
    Welcome to the community!
    I found this one after a short research, maybe this will help. Please click here (it is a different model, but configuration is the same).
    Let us know if this will work.
    Thanks,
    • Bornfree's avatar
      Bornfree
      Hi John,
      Thank you very much for the information. I have read this before but to no avail. What want to know is, what does the log say which I posted eairlier. Doe it mean that the VPN tunnel has created or not? How far in the connection is it going.  Need some ideas as I'm not an expert in IT.
      Thanks
    • Bornfree's avatar
      Bornfree
      Hi John,
      I have tried the setting but i still cannot get it going.
ProSupport for Business
