Bornfree
Jun 21, 2016Aspirant
Problems with FVS336GV2 and AVAYA 9620L VPN
Hi There, I have Avaya 9620L currently working and all setup successfully with netgear FVS336gv3. My problem is, when the phone is switched off at the remote site in the afternoon and back ON in ...
- Sep 13, 2016
Hi DaneA,
The firmware v3.1.1-08 seems to be more stable than v4.3.3-6 at least for my setup here. For the past week i have not had any issues and it works every morning when powered up. For now I will stick to the V3.1.1-08 firmware.
DaneA
Jun 26, 2016NETGEAR Employee Retired
Hi Bornfree,
Just want to follow-up on this.
DaneA
NETGEAR Community Team
- BornfreeJun 29, 2016Aspirant
Hi DaneA,
I only have netgear on the PABX side. The other side (Phone side) I cannot control as the VPN phone is moved from time to time. I have tested it with a few different brands and the result is the same.
The firmware on the netgear has never been updated and that was the next thing i was supposed to do. Currently (from memory) I think it has 3.0.8, which is very old i guess.
I'm currently overseas with the phone and am not able to do anything on the netgear. As mentioned every morning i have skype head office and all they do is change a setting and back to original and i have a connection.
Once I'm back I will try to upgrade the firmware and get back to you.
Thank you for your reply
- DaneAJul 04, 2016NETGEAR Employee Retired
Hi Bornfree,
Just want to follow-up on this. Any updates?
DaneA
- BornfreeJul 05, 2016Aspirant
Hi DaneA,
I'm currently overseas at the site with the Avaya phone and everyday I have to skype my workmate at the PABX end ( Netgear FVS336GV2 end) to do the changes as explained. I will be back at the head office end on this month. I will than upgrade the netgear firmwear and see if my connection stays live.
I will only be able to get back to you early next month.
Thanks
