Bornfree
Jun 21, 2016Aspirant
Problems with FVS336GV2 and AVAYA 9620L VPN
Hi There, I have Avaya 9620L currently working and all setup successfully with netgear FVS336gv3. My problem is, when the phone is switched off at the remote site in the afternoon and back ON in ...
- Sep 13, 2016
Hi DaneA,
The firmware v3.1.1-08 seems to be more stable than v4.3.3-6 at least for my setup here. For the past week i have not had any issues and it works every morning when powered up. For now I will stick to the V3.1.1-08 firmware.
DaneA
Sep 13, 2016NETGEAR Employee Retired
Hi Bornfree,
How was your testing? What are you observations?
DaneA
NETGEAR Community Team
Bornfree
Sep 13, 2016Aspirant
Hi DaneA,
- DaneASep 14, 2016NETGEAR Employee Retired
Hi Bornfree,
I'm glad to know that firmware v3.1.1-08 works fine with your network setup.
Since firmware v3.1.1-08 works best and you have no issues with it, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,
DaneA
