DA2B
Jun 11, 2016Follower
Product replacement for FVS336GV2
Hello the community,
I'm searching an actual product able to replace the FVS336GV2, I don't need WIFI, just 2 LAN connection and the most important is the VPN possibility with the old NETGEAR ProSafe VPN client.
Thanks for answer me.
Regards
Damien
- JohnRoNETGEAR Employee Retired
Hello DA2B,
Welcome to the community!
We have some models that you can choose from. I have listed them below:
For the comparison of these models please click here (see page 3). All of the following models supports the VPNG01L VPN Client software.
Let us know if you have more questions.
Hi DA2B,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
