jwilliam1203's avatar
jwilliam1203
Asymmetric Routing and Keep-Alive
My company is looking to purchase a VPN Firewall but have specific requirements from a vendor we are using. Two of these requirements are difficult for me to validate in the technical specifications...
  • DaneA's avatar
    DaneA
    Feb 05, 2017
    @jwilliam1203,
    I just want to follow-up if you have further inquiries.  If ever there is none and if your concerns were addressed, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
    NETGEAR Community Team
ProSupport for Business
