sc2018
May 09, 2018Aspirant
Can I upgrade SRX5308 firmware from 3.06 to 4.21
DaneA
May 14, 2018NETGEAR Employee Retired
I just want to follow-up on this. Were you able to upgrade the firmware of the SRX5308 to the latest v4.3.5-3 then perform a factory reset and configure the settings from scratch?
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
sc2018
May 18, 2018Aspirant
I plan to do this over the next 2 days. I still do not see why I cannot just upgrade the firmware and move on. The factory reset seems like a waste.
- johngmMay 18, 2018NETGEAR Employee Retired
sc2018,
Typically these "laddered" upgrades include some update to the resident firmware of the device. The process of returning it to a factory reset is to clean up the boot image. Unfortunately taking these out of order has a high probability of creating a misalignment between the operating code in firmware and the boot image.
I don't know if a brick is possible, but you may need to back up and start from the reboot process if the latter updates don't take.
John
