mvaar
Sep 11, 2015Aspirant
FVS336Gv2 full tunnel no internet
I have upgraded the firmware to latest (4.3.3-5) and I am using the latest vpnclient lite version 6.x. Running windows 10 pro 64 bit. I set up the gateway as enumerated in the manual and I can co...
DaneA
Sep 14, 2015NETGEAR Employee Retired
Hi mvaar,
I think if you want full tunnel support, you should use SSL VPN instead and check "full tunnel support" in the SSL VPN Client setup page of the FVS336Gv2.
Check pages 8-15 on the link below. Is this how you configured a client-to-box VPN?
http://www.downloads.netgear.com/files/GDC/FVS318N/QSGVPN_4Apr2012.pdf
I look forward to your response. Feel free to post screenshots of your setup. Welcome to the community! :smileyhappy:
DaneA
Netgear Community Team
mvaar
Sep 14, 2015Aspirant
I followed the instructions in this manual - http://www.downloads.netgear.com/files/GDC/VPNG01L/VPNClient_UM_27May2015.pdf
Remember, I have a fvs336gv2 with firmware 4.3.3-5, not a fvs318.
Yes, it is a client to gateway VPN.
I followed the gateway setup exactly as described in appendix A, manually configuring a gateway, with the addition of (edge) xauth.
I assigned client IP address of 192.168.7.10, while connecting (tunneling) to the remote subnet 192.168.120.0/255.255.255.0 . The endpoint is 192.168.120.1. It is one of the VLANs I set up on the router.
On the router, all outbound traffic is allowed so I saw no reason to add any firewall rule ( as some have indicated elsewhere that to make full tunnel possible you need to add firewall rules or even routes). I am a little hazy on these concepts though, I admit.
So with split tunneling, everything works. I can see the remote subnet and I can ping to the internet- all traffic except to the 192.168.120.0 is going from my local gateway - 192.168.70.1 .
With full tunnel, I can see everything in the 192.168.120.0 as expected but I cannot even ping IP addresses on the internet.
- mvaarSep 14, 2015Aspirant
also, I see this line in the vpn log -
[FVS336Gv2] [IKE] INFO: No policy found, generating the policy : 192.168.7.10/32[0] 192.168.120.0/24[0] proto=any dir=in
I do have a vpn policy but it is declared for fqdn and not the ip address 192.168.7.10. Could this be causing the problem ?
- DaneASep 15, 2015NETGEAR Employee Retired
Hi mvaar,
Have you tried to use Mode Config? If yes, does same problem occur? If not yet, kindly check this link below as reference guide on how to create a mode config record then check if same problem will occur:
DaneA
- mvaarSep 15, 2015Aspirant
yes, I also tried using mode config. Same result, with the difference that my (local) virtual IP is from the pool defined in the mode config. I still get the INFO message that policy doesn't exist and creates on the fly. It seems that the policy only has parameters for in and not out, according to that log message.
Also, it recognizes that the client is behind NAT but treats the peer as my <client public IP>- is that OK ? In other words are the tunnel endpoints as expected ?
I do not like the idea of SSL VPN to expose my full network. SSL VPN is only protected by one user/pwd combination from the whole internet. I think that it is good in certain scenarios and if I can configure the access to a fine grained level inside my private network.
Thanks for responding to my posts.
