mvaar
Sep 11, 2015Aspirant
FVS336Gv2 full tunnel no internet
I have upgraded the firmware to latest (4.3.3-5) and I am using the latest vpnclient lite version 6.x. Running windows 10 pro 64 bit. I set up the gateway as enumerated in the manual and I can co...
DaneA
Sep 17, 2015NETGEAR Employee Retired
Hi mvaar,
Kindly check this forum thread below and it seems similar to your concern. It might help you as well:
https://community.netgear.com/t5/VPN-Firewalls/FVS318N-to-Netgear-PRO-Safe-Client-IPSEC/td-p/501726
DaneA
NETGEAR Community Team
mvaar
Sep 17, 2015Aspirant
Yeah, that is exactly what I want to do; unfortunately I see no solution posted in there either.
I saw something interesting in one of the docs that the last responder posted where the TCP/IP properties for the connection had an advanced option to "use default g/w on the remote network" but I did not find that on my wireless connection's properties. That author was using an older version of windows.
At this point I am curious if it is even possible to get internet access with full tunnel. Can you get it working ? Or is that a limitation of the VPN policy being set ? I tried using "Any" for the local network in the vpn policy ( which is considered wrong by netgear but not flagged as such) but that did not help my cause at all. I cannot see anything else in the vpn policy definition that I can work with.
