snosnk
Jan 11, 2017Aspirant
How does one get an SRX5308 to pass GRE packet to the internal network?
DaneA
Jan 11, 2017NETGEAR Employee Retired
I believe it should. Have you already enabled PPTP VPN Pass through on your SRX5308? Refer to the image below:
DaneA
NETGEAR Community Team
snosnk
- DaneAJan 12, 2017NETGEAR Employee Retired
Here are my questions below:
a. Do you have a static Public WAN IP Address registered to the SRX5308 or are you using DDNS?
b. Have you tried to open ports 500 (TCP/UDP) and 1723 (TCP) on the SRX5308 pointing to the IP address of the Active Directory? If yes, kindly test the ports it if its really open via this link: http://www.canyouseeme.org/
c. Have you encountered an error message when the PPTP client fails to connect? If yes, kindly post a screenshot of it.
d. What is the current firmware version of the SRX5308?
DaneA
- DaneAJan 15, 2017NETGEAR Employee Retired
- snosnkJan 15, 2017Aspirant
Static WAN IP, FQDN
Ports are open and tested. Port 500 is not required as per the list of ports at MS. Opened to test, no difference.
From what I can see the requests are not making it to the server at all. Where would this be logged in the router?
System Name: SRX5308 Firmware Version: 4.3.1-22 Now I have done my best to answer your questions, will you answer mine?
Let me repeat it:
DOES THE SRX5308 PASS GRE? Simple question, a yes or no answer will suffice.
