snosnk
Jan 11, 2017Aspirant
How does one get an SRX5308 to pass GRE packet to the internal network?
DaneA
Jan 15, 2017NETGEAR Employee Retired
snosnk
Jan 15, 2017Aspirant
a. Do you have a static Public WAN IP Address registered to the SRX5308 or are you using DDNS?
Static WAN IP, FQDN
b. Have you tried to open ports 500 (TCP/UDP) and 1723 (TCP) on the SRX5308 pointing to the IP address of the Active Directory? If yes, kindly test the ports it if its really open via this link: http://www.canyouseeme.org/
Ports are open and tested. Port 500 is not required as per the list of ports at MS. Opened to test, no difference.
c. Have you encountered an error message when the PPTP client fails to connect? If yes, kindly post a screenshot of it.
From what I can see the requests are not making it to the server at all. Where would this be logged in the router?
d. What is the current firmware version of the SRX5308?
| System Name: | SRX5308 |
| Firmware Version: | 4.3.1-22 |
Now I have done my best to answer your questions, will you answer mine?
Let me repeat it:
DOES THE SRX5308 PASS GRE? Simple question, a yes or no answer will suffice.
