spaceobh
Sep 27, 2015Aspirant
How to configure FVS318N to transmit NAT'ed LAN IP in FTP tranfers in stead of Firewalls WAN-IP.
I'm having this problem. Remote site is connected to the internet in a fixet, multiple IP-adress MPLS setup. The LAN side is presently protected by a Zyxel Zywall, but for a variety of reasons I...
- Oct 14, 2015
Hi Samir
Apologies for my delayed response.
I'll try to test the setup you are suggesting the next time I'm at the location, but since it's in east Greenland there are no planned trips - I only go there when absolutely necessary.
I will need to close my post here for now, and I'd like to thank all of you for your help.
When I initially opened the case I thought I had just missed to set a checkmark somewhere, and that I could sort of just "copy-paste" the rules etc. from the Zyxel to the netgear.
Cheers
SamirD
Oct 08, 2015Prodigy
If there's no server on the netgear lan, there's no need for any rules for ftp to work (unless you have a double nat, but it doesn't sound like you do). I think the incoming rule may actually be the issue. Could you try removing it and see what happens? In fact, just connect the netgear behind the zyxel--even though it's a double nat scenario, if you're using passive mode it shouldn't be an issue.
spaceobh
Oct 09, 2015Aspirant
"If there's no server on the netgear lan, there's no need for any rules for ftp to work (unless you have a double nat, but it doesn't sound like you do)."
That's what I was thinking - no outgoing rules needed. (yes, no double NAT)
I need incoming rules to filter unwanted traffic, right?
My initial configuration was any-any for outgoing, plus the desired incoming rules in order to filter unwanted traffic and setup NAT.
"I think the incoming rule may actually be the issue. Could you try removing it and see what happens?"
No, can't do that - the unit is at the remote (very remote) location, and I don't want to risk intrusion, in a situation where I'm not present at the site.
"In fact, just connect the netgear behind the zyxel--even though it's a double nat scenario, if you're using passive mode it shouldn't be an issue."
Can't do that either, the netgear is configured with a fixed WAN-IP (same as the Zyxel, obviously) so I don't see that can be done?
This is the setup:
Rules
WAN-IP
