Rubatoguy
Oct 31, 2015Aspirant
Looking for upgrade to fvs338
I have an fvs338 that is fantastic, but my provider is offering speeds faster than the LAN-WAN rating of the FVS338. I don't have any need for Wi-Fi. Can anyone suggest a good upgrade from the FVS338...
DaneA
Nov 01, 2015NETGEAR Employee Retired
Hi Rubatoguy,
You may want to check the FVS318Gv2 (v for version). The FVS318Gv2 has 8 Gigabit LAN ports and 1 Gigabit WAN port. It supports a LAN-to-WAN throughput of 250Mbps which means that if you are subscribed to an internet connection of higher than 100Mbps but not more than 250Mbps then, the FVS318Gv2 would fit to your network setup as your main firewall router. The FVS318Gv2 does not have wireless functionality.
Kindly check theses links below to know more about FVS318Gv2:
http://kb.netgear.com/app/answers/detail/a_id/25749/~/fvs318gv2-faqs
http://www.downloads.netgear.com/files/GDC/datasheet/en/NETGEAR_ProSAFE_VPN_FW_Family.pdf
DaneA
NETGEAR Community Team
Rubatoguy
Nov 05, 2015Aspirant
But the FVS318V2 is listed as an END OF LIFE product. Why would you buy a product that is END OF LIFE?
That does not sound like a wise purchase.
Todd
